brbovin
Member
Focus Stacking
Is there a focus stacking app I can add to my ILCE-7RM2
3 REPLIES 3
Joe_Dohn
Specialist
You can check all of the supported apps in the online portal.
brbovin
Member
The only app I can find is Bracket Pro. According to the description it only takes three images. I have heard of focus stacking that lets the user specify the number of images. For taking macro shots where light levels can be low an DoF is limited this would be useful.
Joe_Dohn
Specialist
I've heard of software-based focus stacking apps -after the fact- but I haven't looked into it much.
I assume it works similar to Lightroom or After Effects, might be worth a look if the camera app isn't what you're looking for.
Hope this helps!
- JD
