Sony A7R III Update
https://www.sony.co.uk/electronics/support/e-mount-body-ilce-7-series/ilce-7rm3
About this download
Benefits and Improvements from the latest update
Support of "SEL400F28GM"and "SEL24F14GM":
New features:
- Optimization of the optical image stabilization performance, and addition of a new image stabilization mode of the lens (Mode 3)(Only "SEL400F28GM").
- Addition of a Function Ring(Lens) to the menu.
Note: For the SEL400F28GM lens, the APS-C S35/Full Frame Sel. setting is assignable to the Function Ring in addition to Power Focus.- Addition of [Aperture Drive in AF] setting in the menu.
*Using the lens "SEL400F28GM" or "SEL24F14GM", when [Silent priority] is selected, the sound emitted by the aperture drive will be reduced. This is useful in shooting conditions where camera.
noise should be kept to a minimum. Note that Auto Focus may become slower when [Silent priority] is selected.Other improvements:
- [AF Track Sens] can be assigned to a custom key.
- When used with the LA-EA3 mount adaptor, all focus areas are supported.
Note : Focus Area options added : Zone, Expand Flexible Spot, and Lock-on AF.
Bracket shooting is available during silent shooting when [File Format] is set to [RAW] or [RAW & JPEG] and [RAW File Type] is set to [Uncompressed].
- Improvement of the performance and the overall stability of the camera.
- Better reproduction of the gradation of RAW pictures.
Note: Imaging Edge softwareneeds to be updated to benefit from the improvement in the RAW processing.- When shooting with a flash in an environment with flickering light sources, the stability of the exposure is improved.
- Improvement of managing continuously shot images as a group.
Please refer to the HelpGuidefor updated function usage.
Voor meer informatie en de Firmware update zelf voor de Sony A7 III zie onderstaande link
https://www.sony.co.uk/electronics/support/e-mount-body-ilce-7-series/ilce-7m3
Opgelost! Ga naar oplossing.
Voor de volledigheid en met dank aan @FOTOGRAFIELAMP kan dit aangevuld worden met
https://www.youtube.com/watch?v=s_EoP28crJA
grt, Sigi
Bedankt voor het delen!
Zelf geen uitdaging mee. Gebruik aantal originele batterijen.
Goed dat je dit deelt...maar bedoel je nu uitdaging of probleem?
kan verwarrend zijn voor minder ervaren Sony gebruikers...
grt, Sigi
grt, Sigi
