Greetings and courtesy to my dear friends Xperia on Android 13 My phone is xperia pro i which has received android 13, except for the home screen photo which came in black color, I have not seen any bugs in the last 40 days. I had a problem with the remote control and Volga handle, which was solved with two hours of reading. If you have Bluetooth problems, be sure to delete the devices you have saved before and then connect them one by one, the problem will be solved, this problem is also from Google that the memory of the past is not compatible with Android 13. The music player has become better. But the music pro program is empty. The controls do a lot more than before, which is great. Digital zoom has been removed! Good luck
The phone works really well.
Proi is the best mobile phone in the world
