z3 low speaker volume after lollipop
puddlejumper
Visitor
Anyone experiencing low volume when playing speakers? YouTube and other videos are really low. Music seams OK. Any fixes that work on non rooted phones. I have a tmobile z3
1 REPLY 1
Phy
Legend
Legend
This has been answered by Rickard
I'm afraid i don't know for sure if this decision was made within Sony or by Google but as i understand it, the global Equalizer was removed in Nexus as well and i also found this: http://developer.android.com/reference/android/media/audiofx/Equalizer.html
"NOTE: attaching an Equalizer to the global audio output mix by use of session 0 is deprecated."
Hi and welcome to the community!
As mentioned earlier, the equalizer is still available for 3:rd party apps but it's now up to the app developer if they want to use it or not. If the application you use doesn't use it i would recommend that you contact the developer of the app to see if it's something they can add.
It may be possible to downgrade the phone using 3:rd party tools but it's not something i would recommend and changing the phones software using 3:rd party tools may affect your warranty. If it's something that you still want to do i recommend that you check http://talk.sonymobile.com/t5/Android-development/bd-p/22051
http://talk.sonymobile.com/t5/Xperia-Z3-Z3-Dual/Equalizer-problem-after-lollipop-update/m-p/972944#M...
