Xperia Z's Loudspeaker Waterproof?
GELÖST
Shoken
Besucher
So I just got my Xperia Z today. I first tested the camera then the music using the loadspeaker volume max. The volume is really high and the music sounded awesome. Then while it was playing, I tried to wash it. Suddenly the volume just went down and emits crappy sound. So I'm not sure if the water entered the speaker. The phone works perfectly fine though. Water Resistant? Now I wonder.. >.>
Edit: So I tried playing a video on YouTube, the volume was loud and doesn't have a problem. Then I re-tried playing Music on my Xperia Z, turns out it works perfectly fine now. It's so weird.. I still don't know what caused the loadspeaker to malfunction but my loadspeaker is working fine now.
Ce message a été modifié par: Shoken
1 AKZEPTIERTE LÖSUNG
Akzeptierte Lösungen
Sam
Legende
Legende
It’s not a fault; there was just simply water in the area of the speaker. It is water resistant, however you obviously need a hole of some sort to let sound out and when water gets in this area there will drop in audio volume/quality until it dries.
What are your thoughts about this forum? Let us know by doing this short survey.
8 ANTWORTEN 8
Uliwooly
check the loud speaker there might be a bit of water
VictorVV
Besucher
I have same problem Neutral_Face .
Sam
Legende
Legende
Edoni
Besucher
i only washed from outside and the loude speaker make now just a little hearing sounds and some creapy it will be fixed of what and how long are you others having this problem and still didn have a change or did it been fixed please write
MattiasA
Besucher
The same happened for me. I put my phone at the computerfan where it blows air, started some music, after a few minutes it was gone and speaker sounded as it should.
moomin14
Besucher
It takes about 3 to 6 hours or even more for the water to disperse. Its normal don't worry. Happens to me all the time when i watch youtube in the bath or shower. Worth it though Slightly_smiling_Face
MattiasA
Besucher
What movies are you watching in shower? Dizzy_Face
rusticguy
Besucher
You watch youtube in bath or a 3X Movie :smileygrin:
