Wifi not working
chofito88
Visitor
Wifi not working
My Xperia XZ is not connecting to wifi. I've tried multiple wifi's at home, work, and even a friend's.  I followed all the steps to try to fix the problem. First, I restarted the phone and it did not work. Then I decided to repair it through Xperia Companion, it did not work. Then I factory reset the phone, and it did not work. What can I do to fix this? I may need to send it to Sony support to fix it.
1 REPLY 1
CameronT
Champion
Hi @chofito88, welcome to the community.
I am sorry to hear about your issue. Slightly_frowning_Face It sounds like you have completed all the necessary troubleshooting. I recommend you contact your Local support team.
