After the recent software update as of 25.04.17 (I'm guessing android Nougat 7.1.1 update) the volume controls on the right no longer do the job. I have to go into Settings > Sound to change the volume now. Please help.
Solved! Go to Solution.
Hi @SERIAL_CHILLER,
Unfortunately, there are an array of things that could cause this type of problem, the fact this was resolved with a software repair tells me this was likely third party orientated or possibly a bad install of the update on the device.
I wish I could advise what exactly caused the problem, however, there are just too many variables.
I see. Thanks though
