USB connection
Diddlyboi69
Visitor
USB connection
Phone is unable to connect to a car radio or dvd player - gives error message N/A USB or USB ERROR
1 REPLY 1
profile.country.PH.title
MarlonUk1
it isn't supported, usb connection is based on MTP, which is for file transfers only.
if you want to connect your device to car stereo, you can use a 3.5mm aux cable then use voice commands to navigate music. or use wireless options
