When I connect the charger at the evening I have activate night mode in smart connect so it should be quite but it doesn't work properly. After about 5 minutes it start vibration. So I can't use it. I have to make it manually and turn smart connect off.
Is it anyone that have a solution?
Hi @Wiski, welcome to the community.
Try resetting the Smart Connect app.
To do this please go to Settings > Apps > Smart Connect > Storage > Clear Data.
Now I have tried that without any progress.
I think it has to do with the new smart battery charging.
After about 5 - 10 minutes connect with the charger the phone start to vibrate and pling if you have smart connect night on.
It's like the phone thinks it's just connected.
