How to tune down vibration
xoxo1
Visitor
I always have had issue with the vibration strength of xperia phones. the vibration is too strong and loud - it is extremely annoying.
I do not want to turn off vibrations completely or adjust the vibration pattern for each app seperately. Is it possible to reduce the strenght of the vibration globally?
1 REPLY 1
profile.country.US.title
Qatrium
@xoxo1
Unfortunately, there's no system setting to reduce vibrations intensity, so that leaves you with 2 options:
1- Root your phone and tweak with system settings (not recommended unless you're an expert user)
2- Try this app: https://play.google.com/store/apps/details?id=com.wbouvy.vibrationcontrol&hl=en
