How to charge xz faster?
Im trying to find the solution but actually there is no solution because sony xz dont charge fast. Cause all possible solutions i already tried it. And what phone is that can charge 60%? My xz also can but in 1 hour ++.. And thats really funny for a smartphone so called "fast charging"
As I said in my previous post, if you think they is anything wrong with your device or the UCH12W charger, I'd recommend that you contact your Local support so they can arrange a repair for you.
Have you also tried charging your device when it's turned off either with the charger that was included with your phone or the UCH12W? If you haven't I would recommend that you do that.
You can also try and charge it in safe mode.
I already tried with uch12w. It is faster a little bit. I expected to get at least from 0 to 50 in 30 minutes. But sony xz cant reach it with all chargers. Anyway thanks for your suggestions.
