I find it very uncomfortable after having the sony ericsson xperia neo v Xperia ARC the Sony Xperia Z Z1 Z2 Z3 Z5 and now that I have the Sony Xperia XZ is the one that has left me with more faults it overheats a lot with the same application of the Previous terminals many reboots me or slows down the operation of the mobile do not know if it is some specific failure or is that the terminal is defective that it should do ??
GT
Hi @Elmaxi89, welcome to the community. I am sorry to hear about this.
It’s normal that the higher speed processor in the device generates heat. It is also normal that the device gets warm while charging, especially if charging when the battery level is low.
Do you experience the same issue in safe mode?
Hello
My cell phone is in repair because of the heat
I have z.b. Only 10 minutes long a video recorded and the mobile announces itself that it certain apps can no longer run and only partially run
End of the song
Display has detached itself from the housing by the heat thereby the I always the in the case has the cell phone slightly bent
Now want the of me 129 euros because I have it (+ data backup)
GT
