Does bared 3.5mm headset jack is waterproof ?
SOLVED
waiwaibb
Visitor
Hello, I bought a new Xperia XZ Dual Sim (F8332) recently, it is a waterproof phone. However, the 3.5mm headset jack is bared, I want to know does it waterproof? Thanks!!
1 ACCEPTED SOLUTION
Accepted Solutions
Lord_viridis
Yes the exposed 3.5mm jack is ip68 rated.
3 REPLIES 3
Lord_viridis
CameronT
Champion
Hi @waibb, welcome to the community.
@Viridis is correct! It is indeed waterproof. There is a waterproof membrane that keeps it water tight. The same membrane is in the charging port.
If you do get water in it, make sure you shake it out and let it dry before you try connecting any headphones or charger.
waiwaibb
Visitor
Thank you very much. Because I am an outsider of waterproof issues. I have a waterproof camera previously which has a waterproof gate. I am the first time to use a bared waterproof device.
