Cant turn on reset do anything with my phone
SOLVED
marcus6
Visitor
Hi
Yesterday I tried to reset my phone with pc companion program. The reset has failed and phone after I try to turn it on show the message Your device has failed verification and will not work properly Your device will be powered off in 5 seconds.  I didn't root or do anything with phone just wanted to reset.  Pls help what to do ?
1 ACCEPTED SOLUTION
Accepted Solutions
marcus6
Visitor
plug the charger let the phone for 2hours and try again repair in Sony Companion  software . For me that works
3 REPLIES 3
marcus6
Visitor
Problem Solved .
frankiebateman
Visitor
how did you fix this ? ! would appriciate the help Slightly_smiling_Face
marcus6
Visitor
