Any body as like as my XZP's problem
It was auto re-start.
Is it software's problem or hardware's problem?
Any one can help me or give me solution, thanks.
Hello @Hung2
Try to restart your phone into safe mode, this will temporarily disable all 3rd party apps. If the issue disappears while in this mode then one of your recently installed apps is causing it, and you'll have to figure it out by uninstalling them one by one or performing a software repair using Xperia Companion.
