cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
kdf-50e2010
ismaelvoltiojaen
Explorador
kdf-50e2010
buenas, necesito saber las funciones de el menu de servicio de sony bravia kdf-50e2010
9 RESPUESTAS 9
profile.country.ES.title
HAL9000z
Lo que preguntas es algo muy ámplio...
¿Qué necesitas exactamente?
He visto por la red que para entrar es el siguiente procedimiento, a parte de algunas funciones que puede que te sirvan (todo bajo tu propia responsabilidad, es algo "delicado" moverse por estos menus así que cuidado)
1. To access the service menu, with the TV off, press the following buttons on the remote control sequentially in rapid succession (note: if the TV is already on, you can start by turning the power off, but then you should enter the full 4-button sequence within about 3 seconds to avoid a lamp restart):
<DISPLAY> <5> <Volume +> <POWER>
2. Press <JUMP> until the PANEL service menu displays.
3. Press <2> until the OPTION_E category appears.
4. The “LampTM” (lamp power-on time in hours) and “LampCT” (lamp on/off cycles) entries are in the first item in the OPTION_E category. If they are not displayed, press <1> repeatedly until they do.
The display should look as follows:
PANEL NVM OK 9 OPTION_E
0 LAMP 0 Diff 1
LampTM #### LampCT ####
To reset these counters, press <3> <MUTING> <ENTER>.
“WRI-EXE” should be displayed momentarily in red text, followed by resetting to “0”.
5. To display the PanelTM (total LCD panel power-on time) entry, press <1> until it displays.
7 SH SFT1 10 Diff 1
PanelTM ####
6. When done, exit the service menu by turning off the TV (note: you can turn the TV back on immediately, but you should do so within about 3 seconds to avoid a lamp restart.
General service menu information
Enter Service Menu = <DISPLAY> <5> <Volume +> <POWER>
Exit Service Menu = <Power>
Menu Next = <1>
Menu Previous = <4>
Category Next = <2>
Category Previous = <5>
Adjust Up = <3>
Adjust Down = <6>
Save New Settings = <MUTE> <ENTER>
ismaelvoltiojaen
Explorador
pues necesito ajustar la imagen osea que no se meta dentro del marco. me explico cuando pongo algo por hdmi se come algo de imagen en el marco y si pongo el rgb osea pc no llega a ponerse la pantalla entera teniendo en cuanta que la resolucion nativa de la tv es 1280x768 y la del ordenador esta igual configurada. y ajustar el keystone osea el trapezoidalIMG_1484.JPGIMG_1480.JPGIMG_1482.JPGIMG_1398.JPG
profile.country.es_ES.title
Hykari
Colaborador
Hykari
Colaborador
En la imagen que he subido del mando si es parecido al mio tiene que tener un botón parecido al que está encima del que pone Exit,
Ese botón es para modificar la pantalla de la tele
ismaelvoltiojaen
Explorador
no puedo ver la imagen y ese boton que dices no me hace nada en la tv
ismaelvoltiojaen
Explorador
ismaelvoltiojaen
Explorador
si, ese boton si lo tiene pero no se ajusta lo suficiente
HAL9000z
Te has asegurado que la resolución que le mandas es la correcta?
https://docs.sony.com/release/KDF46E2010_ES.pdf
Páginas 90 y 91
La resolución nativa del panel es 1280 x 720
Uso del botón WIDE y ajustes, en la página 50
ismaelvoltiojaen
Explorador
si, lo que quiero es encuadrar la imagen con el menu de servicio pero no doy con la forma es algo parecido a esto.
https://www.youtube.com/watch?v=Zhrn92nyIMQ
