Z4 no sound when recording video
bce
Visitor
Z4 no sound when recording movie.
Bad sound if mic is enabled
13 REPLIES 13
profile.country.PH.title
MarlonUk1
are you using the deafult camera app? how about when you use 3rd party apps.
run xperia diagnostics
does this happen when you are on safe mode
Uliwooly
@bce
Your post it's a bit confusing
Are you recording a video but you have the mic disabled, hence no sound?
bce
Visitor
Yes I think it was a year ago or so that movie recording with direct sound worked fine..
Then Sony? removed that option  and forced mlc use to get sound in the recording.
That's not a pro solution? sound gets really bad.
Lord_viridis
Sorry but can you explain further?
Sony has never removed the mic option from video recording.
bce
Visitor
Right, not the mic option but direct sound option.
bce
Visitor
Sorry, it is when I use the built in screen recorder. Long press power > record screen.
Uliwooly
@bce
That's how it's supposed to work, it's supposed to record YOU talking and/or your surroundings NOT whatever it's on the screen, you could turn up the volume of the videogame or whatever you have running
or
use third party app
@Viridis If I'm not mistaken it has been like that since it was preloaded with Xperias, I don't recall if there was a copyright restriction
Lord_viridis
Correct, screen recording has always used the mic for audio, even 3Rd party apps.
There are some copywrite restrictions, streaming media won't record, nor remote play.
bce
Visitor
>I think it is is strange?
>But it is a screen recorder, not i video camera?
>Screen recorder = record the screen, not the sound?
>I need somthing else if I want to record screen with sound? what?
>just looking at YouTube.
or
use third party app
>same problem with third party app.
>Sony (or Google) removed option to record sound and video a year or so ago.
