Anyone know how to get keyboard active on the A105 Walkman. You can’t log in with email addresses using voice type. It’s rendered my expensive device fit for the bin!!! Awful piece of kit
How on earth are people getting on with this? It drives me crazy . Just one problem after another and no easy ways to to fix anything without two hours work.
Hi,
Can you please verify if the latest software is running on your device?
Cheers
How do I access the keyboard on Sony NW-A105 I want to perform a factory reset
