i have a sz2xp/c what is the easiest way to connect to a tv and where do i get the cables
Hi Steve,
Unfortunately, unless your TV has a dedicated PC Monitor Socket (15-pin VGA) there is no easy way to connect your SZ2 to a TV because the Vaio has no Video Out or S-Video Out connection. The only way to get a video signal out is by the VGA Monitor Socket or through the USB Ports.
The RGB signal from the VGA socket cannot be used by a TV with out an expensive adapter LIKE THIS ONE
Alternatively, a more cost effective way is a USB to TV converter LIKE THIS ONE
