Hi, All
i wonder any one of you have idea that how can u know the correct processor installed in the computer. Because in my Vaio FE41Z, when you go to my computer and properties will show different and if you check through vaio dignostic hardware tool and device manager, it is showing different. So, i am confused that which one is right.
if any one can reply for this then i will be very much thankful.
Welcome to the club, At crucial they have hardware scanning software that will accurately determine you processor or at least be a second opinionhere
Hi hir24
The Crucial System Scanner will automatically analyses your Vaio's RAM but unfortunately it will not give information on your CPU..
What information do you get from device manager..?
There is a bug in vista whereby it says you have the processor one lower than you actually have installed. Ie if you have the T7200 then it will show the T5600.
Use CPU-Z to give you the correct information about your processor.
Hi Thalamus,
Thanks for replying. When i am runnning device manager it is showing core 2 duo T5600, 1.83 GHz instead of T7200, 2.00GHz. As per the configaration it should be T7200, 2.00GHz.
Kind regards,
I said that in the post above^^
Run i program that i suggested and you will see that you do have th 2GHz T7200 installed.
What about Sandra 2007?
