When i went to switch on my VAIO PCG-K115S yesterday...i could not get into Windows.
I have recently deleted my girlfriends account on Xp, leaving just mine, and so when i switched the computer on it used to go straight to my account and desktop.
However, now, when it is switched on...it shows the desktop background with no icons, then proceeds to log me off. it displays the 'welcome' screen, with the icon for my account. when i click on the account, it says, "loading you personal details', then 'opening network connections', then i just says 'logging off'...and stays on the welsome screen...
I just can't get in. I tried it in Safe Mode, where it showed my icon on the welcome screen along with an 'Administrator' icon. It does the same thing whichever icon i click...just logs straight off without opening in any way...
I spoke with a friend who suggested this may be a virus which has imported some sort of command to log off instantly...another friend suggested it is a 'Blaster' virus...
So i think i may have to do a system restore...does anyone think this is going to be the case?? Is there any other way around it?
I dont have a real problem with having to do a restore, as a lot of the stuff i want to save is on the 😧 drive...except the Norton Antivirus it came with...
This was pre-loaded and i have since purchased another year's worth...
I'm a bit concerned that i will lose my Norton stuff from the C: drive, as i have no disc to re-load it with...
Can anyone help with my problems??
Thanks in advance...
Damien.
