Trying to add YouView app to above tv, not available in 'all apps' list. Noticed some other glaring ommissions as well (Kodi, ITV HUb, etc.)
Is there a way to update the list of available apps?
Can YouView or Kodi be installed by some other means on this unit?
Opgelost! Ga naar oplossing.
Hi there
The W705C series TV is not an Android based TV (hence I have moved your topic out of the Android TV section).
Unfortunately YouView, KODI, ITV Hub, All4 are only available on Sony Android based TVs. These apps cannot be installed at all on your TV.
Cheers
