What wall bracket would you buy for a Sony xe7 series. Does the xe9 series fit?
Hi there,
The XE9 series bracket will not fit your television. You'll need the SU-WL450 bracket, which you can find here: http://bit.ly/2iVPcDx.
Hope this helps,
Owen
