What type of IR blaster do I need for the Sony KD-55X9005B?
AlexMcMullan
Explorer
What type of IR blaster do I need for the Sony KD-55X9005B? Any info or links would be greatly appreciated :slight_smile:
5 REPLIES 5
Anonymous
Not applicable
Dude - post once please.  Before I could even answer your question I had to spend time removing all your other posts.
To answer your questions: see this linK
http://www.4sony.co.uk/ir-blaster/product.pl?pid=4245380&query=KD-55X9005B
Also available:
http://www.4ourhouse.co.uk/ir-blaster/product.pl?pid=4245380&query=KD-55X9005B
Cheers
AlexMcMullan
Explorer
apologies, is there a item code for this or is this solely the only one sony do and would this work for my tv
Anonymous
Not applicable
No worries :slight_smile:
I do not have the documentation for the product item/code number unfortunately.
On the 4sony.co.uk site, if you do a compatibility check, it comes up with this:
If the item code number is crucial for you, I can escalate this thread to Sony Support for them to find out - however considering its the weekend soon, it will take a few days etc.  Please say so if you do.
Cheers
AlexMcMullan
Explorer
Will the RMF-TX100E work for the Sony KD-55X9005B?
Anonymous
Not applicable
Hi there
The two remotes in question:
The RMF-TX100E is designed for Android TVs which includes an inbuilt microphone and button.  The RMF-ED004 is build for 2014 Bravia TVs.  As I have not tried either remote on each of those TVs, then I can only suggest that you stick to the RMF-ED004 remote control.  Unless another forum member has done so and can confirm or deny compatibilty.
Also note the other buttons of 'Discover' and 'Options'
Cheers
