Problem Ambient mode pictures from google Photos KD-43X81JAEP
AlZoch
New
Hi,
I tried to set the source of pictures in ambient mode to Google photos, some pictures displayed form the selected folder and some of them never appear in the slide show. First I thought of resolution : I changed the resolution to the same as the pictures those come up in the slide show,makes no difference, then I changed the file types to JPEG, PNG but still hided from the slide show ...
is there any specification/prescription for the pictures ?
1 REPLY 1
Anonymous
Not applicable
Did you try to format the stick and test it once more? While formatting it, change the stick format then test it once more, hope it helps.
