loud beep when starting playback of recorded HD media
idunham
New
I have purchased KDL-32WE613, which is working great. However the one niggle is that if I play recorded HD programs from my Humax FOX HDR box over HDMI, there is a loud beep every time playback starts or stops. I'm guessing this is due to a change in picture/signal quality being detected or something similar, but does anyone know if there is a way to stop it happening?
Cheers
Ian
1 REPLY 1
Anonymous
Not applicable
Hi there
Normally in the settings of the TV, there is a way to disable 'system sounds' or 'key tones'.  However I have had a good scan of the manual and I cannot find this setting.  If this is a big issue for you, I would advise you contacting Sony Support to see if they can help.
See:
http://services.sony.co.uk/supportmvc/en/Contact/Email
Cheers
