Freeview auto tune
Effosb
Novo
Freeview auto tune
Any hints about auto tuning Sony Bravia tv for Freeview channels. Freeview website indicates I should get 133 channels, when I do the auto tune I only get 79 which does not include the bbc hd channels. I have other tvs which find the hd channels so don’t think it’s my aerial. I have tried auto tuning without a tv aerial connection to clear memory, and repeat with aerial connection but still does not find hd channels, as recommended by Freeview, so am a bit stumped. The auto tune process does not give me an option to select the transmitter relevant to where I live so wonder if it’s defaulting to one that’s not best for my reception. I am in the Reading area.
any help appreciated.
2 RESPOSTAS 2
daveyh64
Entusiasta
First thing check the fitting of the aerial cable to the plug is correctly done with the solid copper core wire fully through the central core.
If you are happy that the cable connection to the TV is good you could if the TV is not too big and heavy move it to a room where one of your other TVs is and connect it and try to tune to see if you get the full range of channels.
To determine which transmitter your TV should be tuning to enter your address details into the Freeview website here,
https://www.freeview.co.uk/corporate/detailed-transmitter-information
Based on your location the results will give you the transmitters broadcasting in your location.
The first listed will be named ‘most likely’ scroll further down and take a note of the multiplex numbers it broadcasts, these numbers are under the black circle with a white N inside.
Depending on your particular situation you may need to tune to an alternative transmitter, for example in my case my ‘most likely’ transmitter is 20 miles way but due to buildings it is better to tune the TV to another transmitter 40 miles away which has better line of sight and therefore gives my TV much better signal.
If you can determine which transmitter best suits your needs you can then do a manual tune to the chosen transmitter using the multiplex numbers (there are only five) it broadcasts on.
Before manual tuning take the cable out do an auto tune see if that clears the channels.
Cable back in and do a manual tune.
royabrown2
Herói
@Effosb
What’s the model number?
Maybe this isn’t an HD TV.
My favourite bedtime reading is a Sony product manual…
