Bravia internet too slow BT Hub
Lucas442
Explorer
Just bought KDL-32WD754. Signal is too slow to run Netflix/apps even though ipad and iphone when put next to TV show their connection speed is 45 mbs. Have updated to lastest firmware and rebooted BT Hub but no luck.
3 REPLIES 3
Pascale_F
Moderator
Hi Lucas442,
I'll see if I can find this out for you. Maybe someone else in the community can help in the meantime.
Thanks,
Pascale
The_Black_Rose
Specialist
Hi Lucas,
Have you tried connecting to a different network, like a mobile hotspot for example?
Cheers,
The_Black_Rose
Lucas442
Explorer
Thanks for that. I gave up in the end and bought the BT extender which works.
