Делитесь своим опытом!
Hello!
Please may I request help with an odd issue.
I have the above head unit installed in a 2015 Jeep Wrangler JKU. It was installed by a reputable installer in London.
Recently, I have been losing the ability to use the steering controls. So I have to program the buttons every time I use the vehicle.
I've done some research online, it could possibly be the clock spring in the steering wheel which I will change regardless. Last resort, it could be a loose wire at the back of the unit, poss from a rough ride jolting the harness, but would be a long shot.
If anyone has any ideas about this issue, I would much appreciate any input.
Thank you.
