Finger print scanner is not working properly
Prabin11
Bezoeker
3 ANTWOORDEN 3
Martin1
Fan
Hi @Prabin1, let me see if I can help out here!
Could you possibly elaborate your question a bit? For example, are you not able to register your fingerprint in the settings menu or are you unable to unlock the phone using your fingerprint?
Please do elaborate as much as you can and I will do my best to assist you!
Prabin11
Bezoeker
I'm facing problem with unlocking the device.
The device always says clean your finger and senser even I cleaned.
Martin1
Fan
Thank you @Prabin1 for your quick reply!
Have you tried deleting your registered fingerprint and adding it again? Also, it could be a good idea to register the same finger multiple times for optimal recognition.
If that do not work, it might be a good idea to try a software repair using Xperia Companion and a computer. do note that a software repair will erase all user data from the phone, so it is advised to do a backup before the repair to avoid data loss.
Try this and let me know how it goes!
