Sports series 1 - entry-level earphones to get you motivated
scully99
Member
Member
4,881  Views
Need a little extra motivation to stick with your fitness plan? Given up on your New Year’s Resolutions? As springtime arrives, there’s no better time to get back out there.
In our new series of blogs on the best earphones for sport, we’re focussing on inexperienced runners and those of you who want to get in shape. We asked what makes you feel good about your training regime and what keeps you away from the gym?
XB510AS
MDR-XB510AS [EXTRA BASS™ sports in-ear headphones]
Whether it’s body confidence or boredom, sometimes everyone needs a little push - and we’ve got some gadgets to help you. We’ve designed two kinds of in-ear sports earphones for runners’ needs, but you don’t have to be on your fifth marathon to use them. They’re there to keep fitness enthusiasts of any level entertained and motivated, while practical designs mean you can rely on them to stay put.
When you need extra motivation, there’s a Sony technology specially designed to drive your workout. EXTRA BASS™ enhances low-end bass sounds, so that the rhythmic music you play to get you through a tough session is extra punchy and inspiring.
These earphones fit securely with Arc supports and are available in four colours. Even better, they keep you on track when the weather is bad. Rated IPX5/7 washable, you don’t have to worry about using them in heavy rain and you can also rinse them under the tap.
MDR-AS410AP [Sport in-ear headphones]
If you prefer a different design, this model has loop hangers and different sizes of silicone earbuds for a better fit. (Did you know that most people will need different sizes for each ear?)
The choice of colours is designed to match sportswear, so it’s easy to find a striking shade to match your style. These earphones are also splash-proof and come with a compact carry pouch to protect them.
The design of the MDR-AS410AP earphones keeps the sound loud and clear. They have a wide frequency spectrum of 5-24,000Hz, meaning you don’t lose the details at either end of the scale.
One of the biggest reasons for not exercising is being too busy; don’t let that stop you! If you’re someone who needs to take phone calls – whether it’s work or getting support from friends – you can stay connected during your training session with the built-in microphone. You can also switch tracks without having to reach into your pocket by using the remote control.
MDR-AS410AP
Check out both products here to see if they’re right for you. Good luck with your fitness plan and don’t forget to set goals! (We know you’ll smash them!)
https://www.sony.co.uk/electronics/in-ear-headphones/mdr-xb510as
https://www.sony.co.uk/electronics/in-ear-headphones/mdr-as410ap
1 Comment
