- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Hi, I have the 50X90S TV and the HT-A3000 soundbar.
I thought the acoustic centre sync feature was compatible with both of these but I can’t seem to get them to work. I have connected them together with the included cable, but no luck.
Any ideas? Thanks
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
The PDF of the Italian Technical Data Sheet also talks about the possibility of using AV IN for S-Center Speaker, but the X90S Quick Setup Guide does not show the Connection in combination with AV IN...
X90S is not among the compatible TVs in fact:
How to use your TV's built-in speakers as a centre speaker
https://www.sony.co.uk/electronics/support/articles/00201071
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi, are you sure where you connected the cable to the TV, to which input?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I connected it to the “AV in” input. It fit perfectly so I figured it was the right one. Am I wrong?
The support pages suggested the X90K was compatible and the X90S is just the 50 inch version of that, perhaps I was mistaken.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Oh, right. That is disappointing. Oh well.
I didn’t realise the X90S had differences from the X90K other than size.
Thanks for your help.
