On custom settings what is Zebra please.
Hi @Mickarchie,
'Zebra' is a diagnostic overlay, which you can set to indicate different things e.g. over exposed parts in your frame.
It will show a moving pattern which consists of black and white stripes, so you can distinguish it from the also light parts which are not over exposed.
- Nic
Thank you.
'and is it helpful or does common sense work best
Hi @Mickarchie,
that depends on how you use your photos/videos.
If you aren't a pro photo-/videographer, you probably won't need to know whether or not the material is overexposed.
- Nic
Thank you.
