Transfering from camcorder to PC
SOLVED
profile.country.en_GB.title
Condover
Visitor
Is it possible for me to transfer my taped videos to my lap top? I have a Sony CCD_218E, Hi8 camera.
If it is, exactly what do I need please?
Thank you
1 ACCEPTED SOLUTION
Accepted Solutions
Blencogo
Hi Condover.
I assume you have a CCD-TRV218E camera?
If so, this is an analogue Hi8 camera and you will need a converter to change the A/V to the digital format needed by your PC.
Do you still have the original A/V connecting cable shown on Page 123 of your User Guide that you can download from here: -
http://pdf.crse.com/manuals/3079468141.pdf
It has a Yellow video plug and a black mono audio plug connected to a 3.5mm jack plug.  You can use this to connect directly to a VCR Tape Recorder but you will need something like this to capture the output digitally on your computer.  Prices range from £5 to £250 and some come with editing and DVD burning software.
Cheaper: -
http://www.amazon.co.uk/s/ref=nb_sb_ss_i_5_13?url=search-alias%3Daps&field-keywords=video+capture+us...
Mid Range: -
http://www.amazon.co.uk/AVID-8230-10063-11-Pinnacle-Dazzle-Recorder/dp/B001918NLC/ref=sr_1_1?ie=UTF8...
Expensive: -
http://www.amazon.co.uk/Pinnacle-Studio-Moviebox-14-USB/dp/B003OX3W82/ref=sr_1_11?s=software&ie=UTF8...
You pays your money ........................... The more expensive ones also come with better software but you can use third-party software with a cheaper device.
Just a hint.  When transferring from your camera, choose 'EDIT' and connect the mono audio jack to the white input.
Good Luck!
:wink:
1 REPLY 1
Blencogo
Hi Condover.
Cheaper: -
Mid Range: -
Expensive: -
Good Luck!
:wink:
