I would like to know if and how i can install apps on the reader. I have a library app that i want to use to read book. However it looks like the app doesn't work on the reader, it can't be installed. any ideas on how to do this? I expected that this reader works on android.
Hi @BHelder
The Reader runs on a modified version of Android and may not allow installation of your app. However it does have wide compatibility with eBook formats and you should still be able to download and read the same content.
Cheers
Mick
