annulla
Visualizzazione dei risultati per
Cerca invece
Intendevi dire:
Iscriviti adesso. Entra a far parte della nostra community!
screen not functioning.
profile.country.en_GB.title
readwisher
Visitatore
After first use, which seemed to go well, my screen went blotchy, on off stopped working, I could not use anymore. Contacted retailer who said I MUST have damaged the reader. I have never used it.(!)  Am told it will cost same price as new one to repair it...????help ANy ideas?
Tag (4)
6 RISPOSTE 6
specialist-convergence
Visitatore
Hi is there any way you can post an immage, not clear what you have from discription
terbush
Visitatore
Same thing has happened to my reader. Retailer has said it's my fault and could not give any details about approaching the manufacturer.
Although I used mine for a couple of weeks, it is now useless. I am looking to buy another brand that has better manufacturer support.
readwisher
Visitatore
THANK you for the reply, yes I will attempt to take a picture and post. BAsically it is like shadows blacking out much of the screen so impossible to use. The retailer says it is screen damage and they take no responsibility. I have never even read ONE book so me not very happy at all!!
readwisher
Visitatore
Thank you for your reply too....it is amazing that we seem to have spent a considereable amount of money on these items, and we have not had any use. I have been advisedc to write to teh head of EU SOny with  formal complaint. I can pass the email onto you but maybe you should write to the retailer too??
it is so disappointing, as I cannot see a positive outcome and we are landed with junk. I am now avoiding SONY items  like the plague .....
profile.country.sv_SE.title
frefast85
Nuovo
I would try to contact Sony Support directly.
They have been extremly helpful the times I have had to contact them (VAIO screen exchange because of clouding, A900 hot shoe exchange).
IIRC it extremly difficult to hurt an eInk screen, they can take alot of abuse before they break. Your products are defect and should be replaced.
Lynn77
Visitatore
I have had exactly the same problem - the reader was OK the previous evening, but when turned on in the morning it had large black patches. PC World said it was broken, our fault and would not exchange it. It's only a month old and we have looked after it extremely carefully, have no pets etc to damage it overnight. Does anyone have an email for contacting Sony support? I have registered (or I would not be able to post here) but it will not recognise me and refuses to give an email without signing in.
