Imaging Edge
Alan1947
Member
Imaging Edge
Had to Factory reset my Android mobile, and ever since have an issue.
Before FacRes I had Imaging Edge installed to remote control RX100M6  and this worked well.
After FacRes I again installed IE and now it will only pair with camera to upload images.
When I try and connect to perform remote control, it just "Connecting ..." until it times out.  Seems like although it likes the password etc (when I have error it reports Password unaccessible straight away) it seems like there is something not restored since the Fac-Res that is preventing the connect (for only useing remote control).
Any thoughts???
7 REPLIES 7
Strampke
Reset is the anwswer, start from scratch.
Remove imaging edge from your phone.
Restart your phone.
Install imaging edge on your phone.
Start the remote control on your camera.
Scan the QR code on the camera display with your phone from the Imaging Eddge Mobile app.
I bet it will work.
Alan1947
Member
Hi
Tried your steps to the letter, except used SSID/PASSWORD method of connecting, just as I did last year before the Factory Reset.  Phone camera is rubbish at small QR codes.
Still fails while displaying Connecting...
Instead of selecting "Ctrl w/Smartphone" on my RX100M6 , I tried selecting "Snd to Smrtphn Func" and the connection is almost instant (using of course the same SSID data) and transfers of images to Smartphone work fast as expected.
This latter fact surely confirms phone/camera connection is good?
I can't think of any setting (that may be wrong) that could cripple the comms just for "control" alone.
This is all using Imaging Edge v7.6.0 - I had previously tried IE v7.5.1 as that would have been the version I used last year when it all worked as expected.
Interesting observation - when attempt connected to "control", when the link fails to connect the camera is not remembered, whereas once successful for "transfer" the camera and its SSID data is remembered for future connects.
Since phone and camera work for transfer function I am puzzle why the same two devices fail to connect using the same software for camera control operation.
Bat_Rick
New
Hi Alan, reset the camera also, this might work.
Alan1947
Member
Thanks - plan to over the next couple of days - will be back to you.
Alan1947
Member
Sadly no change, still only able to transfer images but not remote control.
Have now emailed Sony as their online chat seems permanently off !!!
Will report if/when I get any help.
Alan.
Strampke
Hoho wait!
Did you set your camera to P, S, A or M?
On auto it won't be able to shoot remotely.
HannahEd01
Community Team
Hey Alan1947, the comment from Strampke is correct. What did Sony tell you tho?
