Old handy cam dvd101E
Mikeyboy91
Hi
i have an old handy cam that does not (for years!) format the mini discs anymore - wondering if anyone out there has a working one or knows of a company that could carry this out - I have a lot of discs which I think contain old films but I can’t view them without the format function 🤷🏻‍♂️ any ideas welcome
6 ANTWOORDEN 6
TheRealOG
Community Team
@Mikeyboy91
These are the steps to play discs on your Camcorder: Playing a disc on your camcorder (Page 56)
Did you try them?
Mikeyboy91
Hi thanks for helping but the handycam itself is the problem it is no longer functioning and therefore I can’t format any old discs although I can play formatted discs on a standard dvd player
Thalamus.
Kampioen
Hi Mikeyboy91,
welcome to the Sony User Community..
I have never used such a service, so wouldn’t know who to recommend but if you do a search for companies that can convert or transfer Mini Discs , you will hopefully find a company that can help..
Mikeyboy91
I think what I’m really looking for is access to a working handycam - that way I can format and finalise the collection of discs I have - those that I had not processed this way won’t play and therefore can’t be converted anyway 🤷🏻‍♂️
Thalamus.
Kampioen
oh ok, good luck with your search..🤞
