Xperia C3 / C3 Dual Lollipop Issues and Feedback
Uliwooly
This thread is for C3 users to report any bugs after lollipop, before you do so, try the following:
If your battery drain faster or the phone seems slower or apps are crashing, it'll be wise to reinstall lollipop with PCC
even better if you update deleting all the apps and settings, keep in mind that by doing so, you can not use the backup & restore app to restore anything.
PC Companion (PCC)
Bridge (for Mac)
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
Because of the limited RAM (1GB) the C3 won't get multi user support
http://talk.sonymobile.com/t5/Xperia-C3-C3-Dual/Want-multi-user-support-for-xperia-c3/m-p/987647/hig...
"The reason for that multi user functionality has not been implemented is the amount of RAM (1GB) so i'm afraid this feature is not supported on this phone. "
This thread it's not to ask when is the update going to be released in your country and/or carrier network. you can read about it here
http://talk.sonymobile.com/t5/Software-Updates/Android-5-0-When-are-we-getting-Lollipop-Which-Xperia...
303 REPLIES 303
sj81
Visitor
Hi there, need some help using c3 having problem with wifi, I clicked on the icon but it's not working
harshilsurti
Visitor
I am facing camera issues
SayemShovon
Visitor
In lollipop,again and again refocusing during recrding a video via back camerabis solved???? Have anyone tried?
akshiv20
Visitor
All those who have front camera or camera issues can just clear cache memory of whole phone from settings and clear data of camera and album app and restart phone and everything works brilliantly
akshiv20
Visitor
Especially for front camera just hold your phone to get good shot and don't worry if you still not get good shots
SayemShovon
Visitor
No work..Sony must fix front camera issues as soon as possible. But for that'll should make Sony to take this issue as higher priority. For that each of us can send an email complaining the issue to Sony care. If they recieve email from us individually,I think they are going to take the matter very seriously. So please guys do it.
hellohelloworld
Visitor
Sony should know this front cam issue,but I don't think they will admit it or make any promise to fix this problem. Just like the back cam bug in kitkat, take 5 months to fix. As a result, transmit the bug to front cam. What I can say is "So funny"!
hellohelloworld
Visitor
BTW, I've been using c3 dual for half year. This phone is quite good, but the camera is so FUNNY. As a customer, the only thing I can do is not purchasing SONY mobile anymore.
jagamri
Visitor
Recently I upgraded to lollipop 5.0.2. After this upgraded my device was very very slow battery backup was very poor. And front camera was not working properly. Kitkat version is superb. Pls arrange my device to downgrade or release a new version as soon as possible. I went to service centre. But they can't give a solution for this issue.
Uliwooly
@jagamri
Don't forget to contact Sony directly with your feedback
http://support.sonymobile.com/global-en/contactUs/
