Xperia C3 / C3 Dual Lollipop Issues and Feedback
Uliwooly
This thread is for C3 users to report any bugs after lollipop, before you do so, try the following:
If your battery drain faster or the phone seems slower or apps are crashing, it'll be wise to reinstall lollipop with PCC
even better if you update deleting all the apps and settings, keep in mind that by doing so, you can not use the backup & restore app to restore anything.
PC Companion (PCC)
Bridge (for Mac)
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
Because of the limited RAM (1GB) the C3 won't get multi user support
http://talk.sonymobile.com/t5/Xperia-C3-C3-Dual/Want-multi-user-support-for-xperia-c3/m-p/987647/hig...
"The reason for that multi user functionality has not been implemented is the amount of RAM (1GB) so i'm afraid this feature is not supported on this phone. "
This thread it's not to ask when is the update going to be released in your country and/or carrier network. you can read about it here
http://talk.sonymobile.com/t5/Software-Updates/Android-5-0-When-are-we-getting-Lollipop-Which-Xperia...
303 REPLIES 303
manpreeth
Visitor
WHERE ARE THE PICS? THEY ARE NOT DISPLAYED ..PLEASE UPLOAD AGAIN..THANK YOU
Ivanfr
Visitor
manpreeth
Visitor
yup
hellohelloworld
Visitor
Thanks for sharing! Oh... Back cam problem this time!!!
rockyrock
Visitor
After lollipop update, front camera is malfunctioning. I took a picture with AR effects . the camera works like before. If I take a picture in auto mode or manual mode. Picture darkens.
Give a try using AR effects.. The front camera works fine .
Ivanfr
Visitor
Camera FV-5 resolv front(dark or brigth) and back(lost detail) camera problems.
sj81
Visitor
I tried FV-5, can't solved c3 cam issue
Chris_Sahotra
Visitor
I'm Having The Front Cam Issues... Before The Lollipop Update Rear Cam Is Useless But Front Was Superb But After Update Rear Behaves Good But FRONT CAM CAPTURES DARK OR VERY VERY BRIGHT PHOTOS THAT i Can Barely See Anything Captured..... plz IMPROVE THIS AS SOON AS YOU CAN!! SINCERELY
Tags (1)
sourabhvc
Visitor
Phone is getting slow and hangs several times while using system apps also. Even after pcc. I have only restored contacts from my google account. Please help. Thanks.
hellohelloworld
Visitor
I am downloading HongKong lollipop firmware. I will report back if the camera problem still exists.
