Translation:
I can't install Sony Xperia software on my PC.
لا استطيع تثبيت برنامج سوني اكسبريا علي الكمبيوتر الخاص بي
I used Google Translate to find the meaning of your message. Kindly post your future questions/feedbacks in English so we can assist you, this is an English based forum.
Can you give more details about your phone's problem? Also, do you get an error message when you try to install Xperia Companion on your PC?
Try pressing Volume Up + Power buttons at the same time for 10 seconds to force restart your phone.
Translation via Google Translate:
Hello. For some reason, there is no installation of ringtones on each SIM card in the sixth Android and the notification Can I fix it
Здравствуйте. Почему-то нет в шестом Андроиде установка рингтонов на каждую сим-карту и уведомление Можно ли это исправить
Your question is not related to this topic, can you give more information about your phone model?
