- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Update problem .. please help me .
Hello ,
i was updating my xperia c3 yesterday and lights went out , when i tried to open the phone buy i got that message :
"software update failed, make sure the phone is connected to the computer and try again."
and cant do anything .
please help me quicley .
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Charge your phone for an hour > on your PC > run PCC > follow all the steps > then try to update your phone once more
The phone has to be turned off
Bridge (for Mac)
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Performing a system repair using PC Companion - This will factory reset your phone and erase all data
Switch off your phone and unplug from Pc (Hold volume up and power for around 10 seconds)
Start PC Companion and select Support zone then Update my phone/tablet then in Blue Repair my phone/tablet and follow the on screen instructions - When prompted connect your phone still switched off holding volume down or back button - This should start the repair or reformat process
If you are using Windows 8/8.1 or a 64bit operating system then adjust the settings for PC Companion and run in compatibility mode and chose Windows 7 or XP
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
thats what iam getting please help me i need the phone for very important thing this hour
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Yes so disconnect your phone from the Pc then when prompted hold volume down and reconnect your USB cable then the process should begin
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Nothing happened , have disconnected the usb cable and waited for 5 seconds then reconnected the usb cable and held volume down button till led flashed a green light then off and nothing happened .
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Odd, what if you press and hold the volume up before you connect it to the computer, you could also restart your PC and try again.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Not detected while the led is blue , i have tried to restart my pc and tried my laptop nothing happens also , i have searched about it before i ask here .
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Open your Device manager and connect your phone in the way mentioned - Do you have a missing driver?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Nah i dont have ..
