unfortunately settings has stopped working
rmclaw
Visitor
Trying to add a lockscreen widget but keep getting this error message "unfortunately settings has stopped working". Need help.
Tags (1)
10 REPLIES 10
Uliwooly
Do you have a taskiller? antivirus? Ram app? booster apps?
profile.country.RO.title
_alexdon_
Try settings-apps-all-scroll down to settings app,clear data and force stop.Restart the phone.
alexdon
Alexander1
Champion
If the suggestions above doesn't help, I would suggest that you try to boot your phone into safe mode to see if the problem may be related to any 3rd party app that you have installed in your phone:
http://talk.sonymobile.com/t5/FAQ/How-to-boot-your-phone-into-safe-mode/m-p/348008#U348008
rmclaw
Visitor
Yes I do. Clean master and CM security
_alexdon_
Remove any kind of task killers or phone optimizers.
alexdon
kaushik147
Visitor
 I have the same problem of settings has stopped, but only when i go to Settings->Security->install certificates from internal storage.
I have tried the ways u have mentioned to clear data and all that.
But it didnt still worked . what should i do.
Tags (3)
Prem2
Visitor
My device setting function is not opened...every time setting is unfortunataly has stopped setting. Is all time on my screen..so what r u doing me.??
Kunmun
Visitor
After following that steps. It shows ''no command ''
kholoudelshiref
Visitor
My xperia c has the same problem I can't access to the setting or the camera
