This is the WORST phone I've ever owned.
Touch is really irritating so I have to use glove mode all the time... Probably it could be software polished but sony obiously doesn't care.
Since last update battery drain is also present.
Sony had good battery life but android (phones and TVs) are total mess.
I realised after I updated to 6.0, the glove mode no longer have the irritating circle thing. Does anyone experience the same also?
If your phone was root, replace exist images with blank images at /system/somc/touch/images, the circles will remove
@00sand00 wrote:This is the WORST phone I've ever owned.
C5 Ultra is one of the best Sony's mid-rage (or super mid-rage how called Sony it) smartphone and if you have some problems with using it, try the first to find problem and fix it, before you complaining here. Often is guilty same user - not device, coz user don't know how to normal use it
About screen touch problem read here, if you still will have problem try repair it. A lot of time repair helping much more neither complains
By the way about Sony's TVs yours feedback is totally lie, coz Sony's TVs are one of the best in the all world. That knows everybody, all experts saying that.
And about C5 Ultra i can say just some minus like: missed IP68 certified (this is mistake my opinion of Sony, coz water protection have much more worst mid-rage models, C5 Ultra as i mentioned classifielded as super mid-rage smartphone. Also missed quick charge or fingerprint. All others things is perfect in this model (keep in mind that this is mid-range model, not flagship)
