Dokter
Visitor
SIM card issue
My Xperia C4 has often restart due to sim removing error. What's fix for it?
Tags (1)
6 REPLIES 6
profile.country.RO.title
_alexdon_
Have you tried another SIM ?
alexdon
Christofer
Champion
Hi @Dokter,
If this happens continually I also suggest that you try using another SIM
Dokter
Visitor
I use same sim through another Sim slot but still facing same problem.
Dokter
Visitor
I'm also facing problem in sim unmounting. Press back mechanism not work. Have to remove with pin or cutter.
Christofer
Champion
I'm sorry to hear that, sounds like these two things can be related to each other. I suggest that you contact your Local support support for more information on how you can get your phone examined at one of our authorised service centers and how to proceed further from here.
Hi88
Visitor
Sim card is not working xperia c4
