Opgelost! Ga naar oplossing.
Hi there,
Install Xperia Doagnostics app and test your phone.
Also you can *#*#7378423#*#* and choose "Service Tests".
Cheers.
It is not a shock resistant phone. However if there are no obvious signs of cosmetic damage and the phone appears to read the SIM and operate normally then it would be safe to say the phone is ok.
Don't forget to mark posts that answers the topic as Accepted Solution.
If you find any post helpful, press Kudos.
What are your thoughts about this forum? Let us know by doing this short survey.
