Hi, I bought a Xperia c3 but dont work the gps. I cant use apps like waze or Google maps. Can you Help me please?
First,you need to enable location from quick settings. Then,it should work.
Have you confirmed on allow google to have acces message? You also need mobile data.
No,sorry.This forum is English only.
Do you have any connection to internet? It is required.
Well,in this case,can you test GPS with this app?
https://play.google.com/store/apps/details?id=com.chartcross.gpstest&hl=ro
