- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
help please. i've noticed my phone was hanging . battery was about 30%. i tried to turn it off by pressing the power button. when it was not responding i pressed the reset button at the back. i did it only once it turned off right away but now its not turning back on. i've read that i need to charge it until the led light turns green. but its been charging for about 2 hours now the light is still red. did the power-volume-button presaing already..please help me..my phone is not even 1 month old.
Solved! Go to Solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I had the same problem and the phone wont recharge or turn on. Soft reset wont do it (Power + volume up)
I fixed it by doing a hard reset. Plug in your USB charger but remove your sim and SD cards, in the SIM slot, there is a red button. Hold it for a few seconds and you will feel 3 vibration (like soft reset).
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I am using sony Xperia E3. suddenly, my mobile got hanged. i am not able to restart. while switching on, it is showing sony. after that it is not going inside. i tried to repair my os by sony pc suite. eventhough it is not working. they told me to press up/down volume key + power button. i tried all. please suggest me some sollution.
- « Previous
- 1
- 2
- Next »
