I have purchase a Xeperia C two weeks ago, but till now McAfee Security not activate,
When put the mobile no for registration.. all time its back to home screen.
pls help.
Solved! Go to Solution.
Are you sure you want to use antivirus?Your problem is that mcafee does not activate?
Yes i want to install this anti virus
Till now i can't activatate MaAfee antivirus................ how can i activate.............
clear chache.... start McAfee....verify phone no... put my ph no removed by alexdon - no private info on the forum.. press conninue.. verifying number ... tife left... then again back to home screen error show " we could not veryfy your phone number please enter your phone number and try again" ..... in this processes i am using 3g connection....
Try to use a wifi connection.Also,contact the app developers.
