How move APS from internal memory to SD card
kohen
Visitor
How to move apps from internal memory to SD card in xperia C??
12 REPLIES 12
MarioTinton
Visitor
Settings -> Apps -> SD card. Tick apps that you want to move.
If you still hit the limit (which I'm sure most of us do), there's no way other than to root the device (and void your warranty) and use apps like Link2SD.
Pra_C
Visitor
I would like to inform you that earleir I was using SAMSUNG & recently bought Xperia C with a tought of SONY XPERIA being better than Samsung, but I was very dissapointed within 2 days of buying this new phone as I could not install all my required apps in SONY XPERIA, which I was using earlier in my SMASUNG handset.
I am using an exteranl SD card of 16 GB, but it seems its uselees as device memory is running out of space and its not allowing to install/upgrade any application from Google Play.
Looking for an earlier resolution/Suggestion from Xperia team, because all earlier feedback from XPERIA team regarding this issue is USELESS.
Your early response will be highly appriciated and honured
9093
Visitor
How I move to sd card on Facebook apps in xperia c?
profile.country.PH.title
MarlonUk1
settings>apps>facebook>move to SD
9093
Visitor
I try these but Move to sd card option not enable.
MarlonUk1
is it greyed out?
reinstall facebook app.
profile.country.US.title
Qatrium
@nolramlb
@9093
Not sure if Facebook app can be moved to SD card, back on Kitkat it was not possible.
9093
Visitor
Not uninstall the apps. It's only option disable.
MarlonUk1
i can move my facebook app in my z5c though,, even when it was in lollipop.
and from facebook support : https://www.facebook.com/help/562346110477712
is it installed as system app in previous xperias?
